Printing Question
I'm new to CC and think it is great so far. I am having a little trouble with printing and thought I might be able to get some help here. Some maps I can print and use the "Print Bottom right" "Print Bottom Left" etc...This way I can print the map into four pages tape them together and make one big map. For some reason there are a couple of maps that when I print "Bottom right" instead of printing just that spot on the map it will move the entire map to the bottom right of the page and print the whole thing. Anyone familiar with this?
    Hi there,
    I'm not sure what's happening there with the map, but Id suggest a different method, as CC3 has a simple function to achieve the same effect.
    In the print dialog set "Tiling" to 2x2 pages and enter a little overlap (e.g. 3%). Printing will now create four pages with the map spread neatly across them. The overlap makes sure you can paste them together easily.
  • That worked good, and is so much easier than the way I was doing it. Thank you very much.
