Question
Well I'm getting better a this and my map is starting to look really nice.
Question in DD3 I want to put a curcualr shaft at the end of the corridor. Is ther a way to get dome depth on the shaft. And how do I pick the background for the circle it keeps filling with the flooe tiles I was using?
Thanks
Thanks
To pick a background, just click on the fill style indicator in the status bar, and select another fill style, or use the change properties after making the circle to change the fill style it is using. If you draw it with the dungeon drawing tools, you can also access the dungeon room properties, and set another floor style before drawing it.
