NEED HELP - FT PRO to COSMOGRAPHER PRO
Ok - here's the deal. I am working with CC2, FT PRO, AND COSMOGRAPHER PRO (COSMOGRAPHER 2). My problem is this. When I export a map from FT PRO as a cosmographer template, I get two files. One is an icosohedral projection in bitmap form - and the other is a CC2 (.fcw) file. Bare in mind that this is the first time that I have ever tried integrating Cosmographer and FT PRO - despite having owned both for around two or three years now (been mostly into Fractal Terrains). Ok - so - when I open the exported CC2 (.FCW) file - I get only a blank icosohedral planet hex map, but NO terrain image at all - just the template (BLANK). Ok - so - what am I doing wrong - and/or - what do I have to do to get the FT PRO image to show up behind / with / as part of the planet hex map template?
