Forest Terrain Entity Order Issue
I have just completed a map and discovered, quite to my irritation, that somehow a section of my forest got messed up. The order of the groups of trees is off, so some are on top of others. I have no idea how this happend--I had simply used the "Terrain Default, Forest Pine" drawing tool in the early stages of my map and it was fine then. I've tried using the "send to back" entity order command, but it is too difficult to select the right "clumps" to send back (it keeps selecting overlapping sections). Is there a command that can reorder the trees to the default? If I delete this section and use the drawing tool again, I have the same problem where the newly drawn section overlaps the old section. See picture below:
