Edit Map Title Symbol Value from Standard Overland Template
Just got CC3 and started on a new very complex map. Unfortunately, when I entered the map title in the New Drawing Wizard, I entered it in filename format rather than how I really want it to appear on the map.
After researching, I know that the actual value of the title is an attribute "Map Title", I can extract it but I can't figure out how to edit it.
I can create a whole new map file and just copy the layers I've already done, but that seems like a rather brute force way to change something that should be simple.
How do I change an attribute value for an existing symbol?
Note that you can also just delete the title, and place a new one. Either as standard text (which is the way you label the rest of the map anyway), or by clicking on the symbols in map
Good luck with your map.
I was going to use just the Text with my own colour but could not figure out the Font "Map Title" is.
