Can I import a map I made with Fractal Mapper 8?
Hi guys, I just bought CC3 and Fractal Terrains Pro and would like to know if I can import the map I made with Fractal Mapper 8 into either of them so I can carry on working on it in CC3 instead?
  • To be precise I made it with The Fractal World explorer - I just want the landmasses imported, there's nothing else on the map.
    I do not believe that to be possible. Your best bet is probably exporting the map as an image, import the image into a CC3 drawing, and trace it manually with CC3's tools to get a proper CC3 map.
  • Damn :( I can export a binary file from the Fractal World Explorer and I was hoping there was some way to either import that or convert it into a format that CC3 could understand. Ah well I guess if it's a no-no then it's a no-no.
    Thanks for the response Monsen.
    You can (in theory) use FT Pro to do a basic conversion. Ralf's "Importing an existing world into Fractal Terrains" tutorial ( http://www.jhendor.de/cc2/tutorials.html ) likely has enough information to do the job.
    But, as Monsen pointed out, it is quite likely faster to just trace over an image in CC3.
  • edited July 2010
    I've just had a quick go with Monsen's technique and it seems surprisingly painless, I'll have a look at your suggestion as well though JS. At the moment though I'm having a lot of trouble with it crashing every few minutes :(
    I'm going to try turning it off and on again...
    Update: Found the patch, that seems to have sorted the crashing.
  • Okay - cracked it :)
    Firstly in Fractal World explorer increase your map size to 2880 x 1440 (globe view) and then export it as a binary.
    Note: I had my map set to "flat with contours" for this but I'm not sure it matters.
    Now in Fractal Terrains Pro go through the following steps:
    File -> New -> Binary File
    Click the choose elevation button and browse to your file in the filename box.
    Now the other settings on this screen should be as follows:
    Pre-sample info:
    4 byte, float selected from the dropdown.
    LSB First (Intel) checked.
    Line Width: 11520
    Header Length: 0
    Wrap Horizontally - not checked.
    File Data
    X Start: 0
    Y Start: 0
    Width: 2880
    Height: 1440
    Map Edges
    Top:90
    Left: -180
    Right: 180
    Bottom: -90
    Missing Data
    No Data: -9999
    Replace checked
    New Value: 0
    Hit OK and then Next and then Finish.
    Job's done.
    Wish I could take credit for this but I got all I needed from this post by Antony:
    http://www.cartographersguild.com/showthread.php?1458-Fractal-Terrains-Image-Resolutions
  • Hmmm...I spoke too soon, the landmasses are there but have an altitude of zero.
  • Well I kind of got it working in the end but the altitude never really came across properly. While working on it though I came to realise that there was far too much continental land mass for a believable planetary body anyway so I've restarted from a random FT global map and it seems a bit better. Interesting learning process though, I didn't realise there was such a wealth of knowledge on the subject out there!
