Tiled Printing question
I am having a problem. I am trying to print a map (115' x 115') as a battle map where 1"=5' on regular 8.5 x 11 paper. But I don't know how to calculate the tiling for it. I also don't know if I should be using landscape or Portrait (though I doubt it matter is this since it is a square map).
For the number if pages necessary, you can simply set a tiling of 2 by 2 pages, check the preview, and adjust the tiling from there until your whole map is visible.
Or you can do a little math: 115' divided by 5' is 23. So you need 23" in both directions on paper. At 8.5" by 11" that's 3 pages in both directions to fit everything. If you can cut off just a little on one side, 3x2 would be enough.
Hope that helps.
One foot = 12 inches so 1" = 1/12' and 1/12 roughly equals 0.08333.
Your *real* scale is 1:60 so typing 1 and 60 should be ok too.
However a scale of 1' for 60' or 1m for 60m is still the same 1:60.
In 1" to 5' the scale is not 1:5 because the units are not the same but CC3 converts anything in feet provided you specified the unit.
Hope it makes sense...
