Mirrored Copy effects problem
kmunoz
Newcomer
I'm noticing a visual glitch whenever I create mirror copies of symbols. I'm using an adapted spaceship layout template that has blur and glow on the symbol sheet. However, mirror copies of symbols I've placed don't show up with the glow around them, and they have a thick inner border that seems to be almost bleeding through from the hull sheet.
On the attached image you can see the effect: the forward/starboard thruster is a mirror copy, as is the aft/port thruster. The symbol just above the aft/port thruster is also a mirror copy.
To correct the current symbols: Use "Move to Sheet" (right-click the Sheets and Effects button) on the symbols and put them on SYMBOLS.
To avoid this in the future: Before using Mirror Copy, make sure your current sheet is SYMBOLS.
Hope that helps.
