CC3: Scrub terrain turning into shadows.
I created a map using CC3 awhile back, and have recently gone back to touch it up and add more shiny bits to it. Unfortunately, when I went to add new landmasses, the Scrub (Foreground) terrain I had used previously (with a light green hue) now only created a large shadow. I have no idea how to reset it to its default state; I've tried changing its color in the Advanced -> Properties menu...and that's actually about the only thing I've been able to figure out to try.
I started a new map, and the Scrub terrain was back to normal. I loaded up the previous one, and it went back to shadow.
I need a place for my orcish vikings to reside...
    Sounds like the fill style for the draw tool might have changed or something. If you go to the properties where you said you changed the color, you can also change it's fill style there.
    If you first use info>list on a patch of shrub that does display properly, you can check which fill style it is supposed to use, and then change the drawing tool to match.
