Quick way to put entities on the right sheets?
So, I have a huge .fcw file, a big map made up of six smaller maps.
I inserted the .fcw files into a new, bigger .fcw file and matched up the maps. That worked fine.
Somehow, however, almost all of the entities ended up on the Rivers sheet! Huh? Wha? How'd that happen? Obviously I did something, but I have no idea what.
Is there some way to quickly make all the entities go back to their proper sheets?
Thanks!
    Sorry, there's no way to do it quickly, once your at this point. I'd hide all the layers (not sheets) and go through them one by one to put the entities on their correct sheets (move to Sheet command).
    But this should not have happened if you had the most recent update installed - before that Clipboard Copy did not respect sheets. So you could install Update 8 (available from the registration page) and redo your copy procedure to fix the problem.
  • Thanks Ralf...sigh. I have version 3.40 and thought it was updated. I guess not?
    I'll download the update.
    D
    3.40 is the most recent version, yes. Then I don't know why your clipboard copy put everything on the same sheet. Sorry.
