Where do I find Flagstone G bitmap?
I'm relatively new, and am going through the user manuals and tome tutorials for DD3. The example settings for creating a room in the tutorial have a Flagstone G bitmap for the floor texture. I really like that texture, but I'm only seeing the Flagstone 1 bitmap. Although similar, it just isn't the same. Does anyone know what setting I need to change to get the Flagstone G bitmap to show up in my available options?
Best Answer
    Accepted Answer
    Sounds like you have started your map from the CC3 dungeon template instead of DD3 dungeon. CC3 dungeon is a cut-back style intended for people who owns CC3+, but not DD3 to be able to create basic dungeons. This template does indeed not contain the Flagstone G fill. It is possible to add it, but you are probably better off just starting a new map in the DD3 Dungeon style.
    LoopysueAngela Robinson
Answers
    Accepted Answer
  • Thank you @Monsen. I did, in fact, choose the CC3 template. My eyes just bypassed the DD3 ones that were at the top. I was expecting it to be in alphabetical order, and when I saw that CC3 turned into SS2 I picked the CC3 one for the dimensions that the tutorial was doing. Now that you have pointed that out, I see the DD3 templates at the top, and when picking the correct template, I now see the Flagstone G bitmap. I'm guessing that it shows the most relevant expansion, if installed, to be at the top of the list. Thank you again.
