Weird Behavior while installing via Wine
Hello, recently I've changed my setup to Linux. Last Pop OS (ubuntu based) as of february 26.
I've been installing the CC3 .exe I have, and so far I've installed the base one, character artist, city designer, cosmographer, dioramas and while trying to install Dungeon Designer I've encountered a problem.
I have my serial number, I get the installation request code and I put them in the validate.asp page in profantasy and copy and paste the reply code from the web. Then, instead of continuing the installation as the previous executables it goes back and asks me for the reply code again. and since the codes are identical I get the same response.
Any ideas about how to deal with that? I've made sure the is no blank spaces or weird stuff on the box, so I don't understand why everything installs fine except this (so far)
Thank you all in advance :)
    Hi Dani. I'm sorry you are experiencing this glitch.
    Please contact Tech Support using the "Support" tab on your account page when you log in.
    https://secure.profantasy.com/service/entrance.asp
  • DaniUGDaniUG Traveler
    OK, I'm going to put all the trouble I get installing it on my set up here. just in case someone has any ideas or anyone else in the future has some similar problem.
    Fractal Terrains 3 -> I do not know if it accepts the answer from validate.asp because it tells me Invalid Serial Number although the key has been copied and pasted.
    Symbol set 1 -> Same as Fractal Terrains
    Symbol set 5 -> Same as Fractal Terrains
    Symbol set 6 -> Same as Fractal Terrains
    Tome of Ultimate Mapping -> Same as Fractal Terrains
    World's Builder Companion -> Same as FT
    WW2 Interactive Atlas -> Same as FT
    Cartographer's Annual 13 -> Won't launch via winetricks unlike the rest.
    Cartographer's Annual 17 -> Won't launch via winetricks unlike the rest.
    Also @Loopysue thanks a ton for your extremely quick answer. I will do so. :)
    Loopysue
