Uninstall procedure
I may need to uninstall and reinstall CC3+, but I can't find uninstallation instructions. Is there a procedure for this?
You can try the installer if you still have it. Run that it will also give Repair and Uninstall options.
If not just re-download from your profantasy downloads page.
You can also uninstall CC3+ from the Windows' list of installed programs.
That did the trick. However, everything stayed the same! What I've misunderstood is that there were two folders, but because I've installed in a non-system directory, the Profantasy/CC3Plus folder is the data directory. What I really was trying to discover was where I had to place the extra material that was supplied by Humble Bundle, e.g. CA2009_SettupForCC3Plus.exe, or should I click that setup program and see if it appeared in the CC3Plus folder.
All those installers just need to be run and they will install the components where they should go. You don't need to copy them manually anywhere.
(If you opted for the full Humble Bundle option, you'll have quite a few installers to run)
