Accidentally Deleted Sheet Effects Preset
Hi, I'm new to the software and accidentally deleted the CC3 Mike Schley sheet effect preset. Is there a way I can restore it? Alternatively, does anyone know the specs so that I can reproduce it? Any help would be appreciated.
  • Others here are savvier than I am, but what about reinstalling the main software?
    Don Anderson Jr.
  • Yea I would second just re-installing, or repair option.
    If it is still installed, when you run the installer again it gives the option to repair in most cases. It shouldn't disrupt anything you've done to date.
    Royal Scribe
    edited April 27
    You don't have to reinstall the software. That preset is embedded in the map template, and can be regenerated from it. The preset is only needed if you need to re-apply it to the map for some reason.
    To recreate the preset, start a new map using the right style, the CC3 Mike Schley Overland in this case using default settings in the new map dialog, then enter the Sheets and Effects dialog, make sure effects is turned on (otherwise the options are greyed out), simply hit the "New" button to create a new setting based on the current map, and name it CC3 Mike Schley.
    LoopysueRoyal ScribeScottA
  • Thank you for the help! Running the installer for repairs did the job.
    Don Anderson Jr.
