WIP: Harrier Class Spaceship
Hi,
I've been away a long time, but back again. To learn a little bit more about Cosmographer I've tried to recreate the HARRIER from the Traveller Campaign "PIRATES OF DRINAX", which I will continue to master in the near future. (My players renamed the spaceship to RED DWARF). There are a few things I am not so happy with currently.
First of all, all the staterooms should have bunk beds (2 beds above each other). I have no idea how I could map that.
Also I've connected the weapons to the wings although they should be centered. One on the top of the ship, one below of the ship.
Any ideas?
The Cosmographer /Deckplan /Furniture symbol set has a variable symbol labeled "bed" variation #6 & #7 are bunk beds. The Modern/Floorplan/Furniture (private) symbol set also has bunkbeds. There may be more.
As for the guns, if you consider them as decks and treat them graphicly the same way as you did the crew deck. That should work. YMMV
Thank you. I'll take a look at it tomorrow.
So, I've found the bunk beds. I'm now using the ones from the modern style. Thanks again.
