Problem with Installation location
Hello,
I have a small NVMe drive for my C drive on my computer, but a larger NVMe drive that I store all of my applications on. I have installed CC3+ and want to install all of the additional content that I have purchased, but because I didn't install CC3+ on my C drive, the other installers can find anything. Is there a workaround for this?
If not, what's the point in letting us install CC3+ to another drive?
Thanks for any help
    The other installers should be able to find CC3+ wherever it is installed.
    Have you run CC3+ once after installing it and closed it again? Have you moved anything manually? If the problem persists, please contact us at tech support via your registration page!
    Don Anderson Jr.Andrew RiebeLoopysueKertDawg
  • Thanks for your comment, I tried it again after running CC3+ and now it all works. I appreciate the help!
    RalfDon Anderson Jr.
  • 2 months later
  • Trying to install CC3+ and all the addons to my D:\ drive
    atempting to add the update 28 i could not find CC3+
    open and clost the App and it is installing - i looked at the shortcut on the desktop and it shows that in is in d:\ Drive but targets the Profantasy folder that is on C: ? why did it put a folder on C: drive ?
    can the c: drive folder be moved ?
    Quayuazue _
    Darren McDowell
    edited June 2025
    When CC3+ is installed, it installs 2 folders, the program files, and the data directory.
    The program files folder is extremely tiny (less than 50MB), and is always installed on the C drive. (c:\program files(x86)\ProFantasy\CC3Plus)
    The data directory is installed to wherever you pick in the installer.
    You can move the install folder away from C, but I do not recommend messing with it. It is extremely tiny, and does not take any real space at all on a modern drive, even if you have a real old tiny one.
    LoopysueRoyal Scribe
  • Probably every modern app is over 50Mb by a ton. Virtaully any game is over a gig nowadays. Games at 150 gigs is starting to be pretty common.
    Heck 10-20 pictures would be 50 mb or more.
