Where's my file?
I tried to export a map by following a tutorial video. I saved the map as a JPEG file and did as the video said. CC3+ made the required passes over the map. But now I can't find the exported map. When I click on what I think should be the JPEG map on my list of recent files, Windows tells me the file has been moved or renamed. What's going on?
Try looking in the folder where you saved it, rather than the recent file list.
If you can't find it try exporting it again, but make a note of where it is being saved - what folder and where. Make a special place in your Documents folder for all your FCW and image files to keep them separate from everything else and tidily all together, if you haven't already done so.
Okay, that worked. Thanks!
