I'm having trouble installing the latest version of FT3+ on a new Windows 11 ARM computer. Everything in CC3+ installs and runs perfectly. I get this error message with FT3+:
I suspect it's just a problem with the installer. There's a known issue with InstallAware. Is it possible to get a different installer for FT3? Otherwise, are the registry keys known to manually set instead of the installer?
FT3+ should be able to create its registry keys if you can get the installed configuration over to another machine. The big thing is the "@.ini" file in its Program Files area that needs to be set correctly (to point to the ProgramData area where all of the content goes). I say "should" because I've never tried it and don't have an ARM machine to test with.
Thanks.
That worked perfectly. Thank you!
