Building a space station
Hi, everybodies. Thanks for the help last time
this time I'll be trying to build a Space Station but a big one (for those in the know, I want to try to draw Extropia from the Eclipse Phase TTRPG). However I don't know where to start, those there is a video somewhere ? Have you useful tips ? Does Cosmographer can do something like that ?
anyhow, every bit of help will be greatly welcome !
  • If you are just making a map of each level of the station, then you would want Cosmographer.
    edited February 2025
    This is a live mapping session by Ralf that demonstrates what can be done using Cosmographer. I've given you a link to the right place in the video for how to draw a starship (which I think was of more than one level), but if you've never used Cosmographer before you might want to start at the beginning.
    I hope that helps :)
    Royal Scribefil
  • filfil Traveler
    @JulianDracos this I've figure, @Loopysue yeah I've watch this video however my mane problem is that Extropia is a 100,000 soul space station, that is a anarco-capitalism paradise. It's more a little city tether to an asteroid.
  • It doesn't matter if it is more like a city or not. What matters is how you think it looks. If it is a space station, then it is metal. You just use the tools to draw how it looks. You make multiple levels. From there, you will likely need to learn how to use various effects to adjust the look to match your feel.
    On the other hand, if it is like the inside of a carved up asteroid, then you might want to use DD3 to draw the caves. Then, you add in items from cosmographer.
    filLoopysue
