is there a Beaumaris template?
I would like to explore Beaumaris Castle but I can't find it via the NEWWIZ (New map) command but its not in my Castles folder or Perspectives one, yet the symbols are sitting in the Perspectives folder. Is there a template or is it simply a symbol set?
Best Answers
  • edited February 2025 Accepted Answer
    It is Annual 149, @HelenAA (2019 Annual). Hope that helps.
  • WyvernWyvern 🖼️ 273 images Cartographer
    Accepted Answer
    It's actually a set of maps and their accompanying symbols.
    The simplest way to explore the Castle's Annual is to navigate to wherever you have the Annuals stored (usually in ProgramData/ProFantasy/CC3Plus ), then go to /Annual/Issue 149 – Beaumaris Castle once you've done that. Load any of the FCW files, and you'll be able to navigate to all the rest using the hyperlinks in each floorplan level, and the 3D view version of the whole castle. You'll also find the PDF Mapping Guide for this issue in the same folder, which explains more about the whole project, and the Castle itself.
Answers
