Question about CA143 Asian Town "well" symbol
Ricko has recruited me to design a monastery in a part of the Atlas that he's working on, and I am designing it using CA143 Asian Town and CA141 Japanese Temple.
There's a symbol puzzling me: a building labeled "Well" that has a purple polygon attached to it. There's no reference to it or special instructions that I saw in the mapping guide, and I didn't notice any special sheet effects that might do something (though I may have missed it), and it doesn't appear to be varicolor. It's on the left side of this export.
I'm not seeing this myself.
Check it's not on the MERGE layer using List in the Info menu.
If that's not it, try hiding one of these two layers - hitting apply each time you hide a different layer.
EDIT: I'm either having deja vue, or this problem happened before when the set was first released. That no one has mentioned it since seems to suggest that Ralf corrected something. Check the age of your installer for that year, and unless you have restrictions on your broadband I recommend downloading a fresh copy and doing a repair /reinstall.
It was not on the MERGE layer -- it was on BLDNG (RELIGIOUS). However, hiding the STRUCTURES (COLORS) sheet (the second one that's plural) did the trick. Thank you!
That's good news - unless you ever want to have that layer visible for any reason in the future. I would still check the age of your installer and possibly download a newer one.
I bought it in April 2024, but can't hurt to re-download and reinstall it. Thank you!
If the well still has the problem in the redownloaded and reinstalled version, please let Support know. I think all it is is a slipped polygon part within the symbol itself, but current installers shouldn't still be having that problem.
I re-downloaded the 2018 annual, uninstalled it, and then re-installed it. Still experiencing that same oddity with the Well symbol. While hiding the STRUCTURES (COLORS) layer is a good enough workaround (I probably won't need to show it for this map), I will alert Support anyway. Thank you!
