I love how that central corridor is made to look snake-like, culminating in a room that looks like a serpent's head. But I especially like the two wall extrusions near the "head" also look serpentine.
Can you explain how the top structure relates to the bottom (or is it a secret?). There doesn't appear to be any entrances to that part. Are they secret? Is it accessed magically? Is it on the same level, north of the larger structure, or another level higher or lower?
Full disclosure I forgot to put out: the design of the dungeon is not mine. Well, I used an existing map and altered it a bit.
The top chamber is below the topmost part of the bottom chamber. I'm using it in FGU so need the maps 'together' so-to-speak.
All of it (at least for my version) is carved into the side of a volcano which is comprised of 'green marble'. On the newest version, I lightened the green some more---not so dark.
I used a bitmap to draw what I wanted from the original map. Easy peasy.
Looks like it's going to be an interesting map :)
It's going to be devastating to my adventuring group muhahahahah
Are the green plants maze-like plants?
Heyyas, Ricko
No, just green stone.
Cal
Green marble! I forget what I'm doing in this place and start looting the walls! 🤣
I'm very intrigued by this.
When I first saw this I was going to suggest worn path through the structure, thinking it was all outdoors and grass.
Is it carved from a natural marble node (you geology peeps can tell me the term) or is it tile, or big huge slabs?
Hey all, thanks indeed...
Cal
