How does multi-floor works
Hi,
Does using multi-floor does anything except creating a legend between floors? Can I align some items (like stairs) between floors?
    There are some handy live mapping sessions dealing with multi-level dungeon maps.
    Try this one: https://www.youtube.com/watch?v=Ani2oYh_dMg
    Ralf generates a floorplan from a city building in the video, but you can generate a multi-level map by adding a number of levels to your new map in the New Map Wizard. After that the work is very similar.
    Generally, if you start one from scratch using the New Map Wizard, you draw the main walls and add the stairs to the ground floor level, and then copy those things to the other floors, altering them as you go if the building has different extents on higher floors. Ralf covers copying in the video.
    Don Anderson Jr.Wyvern
