Cosmographer resolution problems
Hi,
I'm using the Cosmographer sector (Spinward Marches) import for traveller and the output resolution is very bad quality (the text is unreadable). I've tried resizing the map in CC3+ but the quality is still poor is there a workaround to create a much higher basic resolution maybe even 3-4 passes rather than just one.
thanks
The size of the map in CC won't affect the size of your export.
Hit the Options button once you have selected your bitmap export type, and use any of the controls in the dialog that opens to increase the size, resolution and other output options.
You can use any parameters you like, as long as the "Work size" (bottom right of the dialog) doesn't go much further than 10,000 x 10,000.
:) Excellent thank you, Looks so much better in A1 poster size (46 Passes)
Oh my!
Looks like we also need to sort out your Maximum Pixels Per Pass quantity.
Type "EXPORTSETMPPP" and hit return. In the command line you will see a number, which is most likely to be 4000000 (4 million). Type 40000000 (40 million) and hit return. Then try that export again.
Thanks I'll try that next, my comp handles it pretty well though only took a few mins, I got a very good result and thats what matters :)
It should reduce your passes to about 3-4.
