Unable to uninstall CC3+
I have CC3+ installed and am trying to uninstall it, however, when I run the uninstaller from Add or Remove Programs, it tells me I need to browse for the original installation sources. 🥴
But I don't know where to point it, so I click Cancel which results in
So, I re-downloaded CC3+, and then tried to install it, but it said it existed already in C:\Programdata\Profantasy, so I renamed the Profantasy folder, and then did a full installation.
Trying to then uninstall CC3+, I encountered the same situation as above.
Please help. No, I am not okay with just letting something linger (per another post) and I am not a fan of hacking to get something out. I am okay if someone knows where the source files I should point to are. I just want the uninstaller to do its thing. This is very weird.
Windows 11
Thank you.
    I recommend you contact Tech Support, Brian.
    You can do this via the Support tab when you log into your registration page.
    TS is usually very fast to respond. However, please bear in mind that this is a holiday week.
  • Do you have admin privledges or are you using the run as an admin?
    I had issues installing earlier when running as admin. I had to change my settings on my new desktop.
  • 4 months later
  • Hey Brian,
    I just hit EXACTLY the same issue re: setupvc12rtm_86 error when trying to uninstall using "Add or remove programs". I'm on Windows 11 and use a regular local user with a separated and dedicated admin account for installations/elevated privileges/User Access Control.
    I uninstalled CC3+ by rerunning the installer again as administrator. It then gave me the options to "Repair" or "Remove" the installation. It was uninstalled off my system without an issue.
    I also couldn't get the "Random Dungeon" plugin working for CC3+, as it couldn't find the installation directory (weird UAC oddities). I suspect I need to elevate my local account to admin privileges, install CC3+, then revoke them again.
    I hope that helps, mate 😁
