How to correct a zig zaggy edge without drawing it all again
I was tracing around a bitmap and didnt manage to get a straight edge down the side of the drawing area and so I got some zig zags.
the bottom point should go the left edge and run straight up so it doesnt look like a peninsula.
Could someone point in the right direction to fix this without redrawing it.
I thought deleting the nodes would do it but I cant see the nodes to delete.
I have tried a few searches here and in the tome and help files but am not sure what to search for
thanks
If you pick the original drawing tool you used to draw the land there is an option to edit an existing landmass.
You have to make one click first, then press E for edit and follow the instructions in the command line.
