Scaling Text with Zoom
Is there a way to have text scale with the zoom of the map? I add text to something on my map but when I zoom out the text stays the same size, becoming much too large and overflowing the box it's supposed to be in.
    Unfortunately the scale at which labels appear in CC3 at a given CC3 scale is controlled by Windows, not CC3 itself. So it varies depending on how far in or out you are zoomed.
    Some fonts are better than others. It looks like you have a font that is quite a bit less predictable than most.
    Try exporting the map to bitmap at the desired scale to see whether you need to increase or reduce the scale in CC3.
  • Thanks for the info. I played around with it some more and I found that I can explode the text (edit->Text->Explode) and that works. Of course the text is no longer editable as text.
    Loopysue
