Cannot see object when I am moving, resizing, rotating - a new problem
Quenten
🖼️ 111 images Mapmaker
Something has happened so that now, whenever I move, resize, or rotate an object - lines, polygons, symbols of both types etc, I can no longer see the object while I try to resize etc, and have to either replace it, or guess.
I have looked in options to see if there is something I should check or uncheck, but no clues.
HELP!
You may accidentally have told CC3+ to skip redraws for faster performance. Try hitting Tab while in the middle of doing one of those operations.
You can also check your settings under Tools -> Options -> Editing Options. You normally want the dynamic cursor option.
The hitting TAB did the trick, thanks, Remy. I already had the dynamic cursor option turned on. Phew!!
