[WIP] Sarah Wroot Revisted
So I like her work, but I don't think the style does it justice. The main thing is that her style has an almost watercolor quality with terrain colors blending. I was hoping the revised style would make it easier to duplicate, but it does not.
So I have created a lot of different terrain sheets and altered the effects. Part of me thinks I might be better off using blend mode for everything instead of blend or transparency.
Here is my attempt so far.
So I changed the bottom center forest to a swamp. I am not sure I like the water. I have played around with blending the greens. Not 100% satisfied, but adding a bit of a glow to one of the sheets helps a bit with the different green layers.
I am disappointed in the lack of cliff symbols (FYI, the vc are not vc, but brown). Mirroring helped a small amount. However, the hill lines came in very useful so I was able to use those to help out.
