Confused about overlapping terrain
I think I may have inadvertently enabled an option or something, because CC3+ is acting differently than it has in the past. For some reason hills (and maybe other terrain) are overwriting other nearby terrain that I add - this did not happen before so not sure if there is an option I turned on to make this happen. Example attached - I made the hills first, then added the forest - before the forest would be separate from the hills, but now the hills seem to overwrite part of the forest I added. Would appreciate any help.
It looks like the sheets are in the wrong order.
Open your Sheets and Effects dialog and make sure the sheets are in this order.
Sheets that are lower in the list are drawn last, and so appear to be on top of everything else in the map.
