Still having a rendering issue.
A while ago I was having a rendering issue. This time around, when it gets to 20% saving file it completely shuts down the program. It causes an error. I believe its a CC3 error. I actually updated some places in my map, "Mahdran Version 2." I tried several different ways and they all give me an error such as the program isn't working properly. I noticed the set up is a little different with the new update. My maps dimensions are 10,500 by 6500. The last time I rendered it I used the pixel resolution of 10k by 10k and it worked fine. Any suggestions would be great. I would like to render it at high quality like the previous map. And the funny thing is I have 5000 less symbols in the new one.
You should turn off antialias, and export to BMP. If that fails then reduce the resolution. Working up from a lower resolution is the most efficient.
