Strange Artifacts
Calibre
🖼️ 39 images Mapmaker
Hey all,
After using watabou and working on labelling my city map, lines are appearing in my number labels:
I've tested this with outer glow and glow; I've hidden everything above TEXT 5. Weird thing is, sometimes, when I magnify to just a number, the lines vanish, other times, they remain. And they do show in every render I've made. The buildings are on buildings low, some on building high.
Any ideas?
Cal
PS:
That's because the text is the same color as the outlines of the buildings below. Try changing the text to a very dark grey instead of black.
Ahah! Thanks indeed, Ralf
That did the trick, Ralf. I knew I'd seen this issue before, but memory comes and goes heh.
Cal
had same problem here time ago, Ralf saved me with same advice. Now i never select black as text color, always a dark grey and never happened again.
