Another little battle map
My players are travelling oveland for a while but some dungeons are a'coming... SS2, Forest Trail and Creepy Crypts work well together. A place to encounter other travelers on the Shattered Road.
Wow, that's impressive!
@ Royal Scribe, thank you!
Another map showing a nicely blended mix of styles - well mapped :)
Thank you Loopysue
Updated the image with some shadowing and highlighting of contours to give the stone depth. A texture overblend using a third party textured fill was used. I also set the Global sun direction in Wall Shadow Directional Effect so that most of the tree shadows fall on the "rock faces".
Just a thought, but did you set up the trees so you can hide the canopies, yet still show where the trunks are for use in ground combat? Of course, that also means you can hide any GM-placed traps under the canopy cover as well 😉!
Hi Wyvern. No I did think of having a tree canopy sheet that I can hide for combat. What an excellent idea! I will use that on a future battle map. I'm calling this one done for the moment.
My knowledge of nature tells me that it is actually a large snake disguised as a road 😥
There ya go. Its always something.
