Contour Lines in CD3?
Hi all -
Is it possible to use contour lines in City Designer 3?
I am attemping to use the contour tool, and I get the following error. Is this because I'm using the Cities of Schley set? If so, why won't it let me select one of the base CC3 contour lines when I right-click the contour tool button? On a side note, is there a different contour button I need to add to my menu? I looked in the help documentation, but I keep running into issues where I can't follow the (broken?) links...see attached.
Thanks in advance!
