To Colour or not to Colour?
I am using Mappa Harnica Tool Kit with CC3+, the colour version. Some of the furniture symbols are in colour, some are not.
The original map I am working on was copied over from a black and white version.
Has anyone else encountered this problem and better yet, solved it?
Thank you in advance.
    If your original map included symbols it could be symbol naming. CC3+ stores the symbol definition in the drawing, so if you already have a symbol with the same name in the map, it will continue to use that definition instead of the new one you try to place.
    You can purge unused symbol definitions from the symbol manager, as well as rename them to avoid collisions.
