It there a way to turn lights off?
I couldn't figure out how to turn one or more lights off after I add them to a map. I would love to do a map with multiple modes, some without lights some with, or a map with the lights in different places for different conditions. I can hide layers to change a maps look, but hiding the layer with the lights doesn't hide the actual light coming from it.
Thanks!
Hiding the sheet the lights are on should deactivate them, so you could set up more than one LIGHTS sheet and split the lighting between those sheets to be able to have different lighting setups.
If you want to deactivate lighting, theoretically it's possible by opening the Global Sun settings (in the right click menu of the sheets and effects button) and turning the shadow transparency up to 100%.
Remy Monsen has a video tutorial, but it's kind of complex. I addressed it by having two copies of my map, one with lights and the other withot.
Oh, that isn't a terrible idea. If I put the lights on last when everything else is done.
