Problems getting bitmap fill to scale
I really want to use the Castlewall bitmap fills on these maps, but I cannot get them to look good.
jpg and fcw.
jpg and fcw.
I can't see a great deal because there are many fills with similar names and all of them are red X to me, but if you look at some of the ones called Castlewall xyz they have no scale at all, like this
You need to check the Scaled box and play with the Width and Height.
Check you are scaling the correct fill by using List. There are so many similarly named fills in the map that you might be changing the scale on the wrong one.
I made sure I was getting the correct one. I'll keep trying.
