Monkey Frog is giving problems
Happy New Year to everyone even though it is s late wish!
I'm attempting to map with MF's template but I'm having immense problems. Yesterday I started to create a map and drew a couple of bodies of water and put some mountains in.
However I didn't really like the size so I tried to delete them. I couldn't, so I did the List command, to see which sheet they were on since in desperation I was going to delete the sheet and create another with the same name, but once more I couldn't select any of them.
This is when I hit my second problem. Having picked a mountain, when I attempted to place it, all it did was grow bigger or smaller as though I was holding the Control key down while I moved the pointer.
I attach a screen shot and the .fcw file in the hopes that somebody will be able to replicate my problem and tell me what is going wrong. Thanks.
They are a set of random mountains of different sizes. That is why they change sizes.
I didn't have a problem deleting anything. I did remove the mountain outside the map, upper left, here is the fcw.
Th ep osted map is perfectly fine here, so it must be something with your system. It does sound like the mouse is not working properly (at least in CC3+). Have you tried restarting everything, including the PC?
I'v removed all the symbols from the map in the attached version. Does it work any better for you?
Thanks both @JimP and @Ralf , I'll look at the maps later. I've only just got up - very late!
