Custom Toolbar Buttons issues
Hello,
I started working with CC3+ recently and still learning basics. To do so I'm following "Hanin's Chapel - A Cartographer Annual 46 Tutorial" by Joachim de Ravenbel.
The author sets some custom buttons for the toolbar related with some macros added in a custom version of Fcw32.mac file (namely myFcw32.mac) and with some Icons in .bmp format, the first put into the C:\ProgramData\Profantasy\CC3Plus folder, the latters put into C:\ProgramData\Profantasy\CC3Plus\Bitmaps\Icons folder. Then I modified the dungeon.mnu file with the rows referring to the toolbar buttons as in the following example:
#27,#Bitmaps\Icons\CONS.bmp:[Construction sheet/layer]{}|MCONS;
Filename and path are correct, button squares appear, macros onclick work, but the bitmap is not visualized (every new button is blank). I also tried to create different version of the .bmp following an advice found on this forum and so now I have CONS.bmp, CONS24.bmp, CONS32.bmp and CONS48.bmp in the Icons folder, but still nothing, it only works with "standard codes" as for example:
#27,PERIWALL:[Construction sheet/layer]{}|MCONS;
Any advices? Maybe I missed something
Thank you very much in advance,
Regards
    edited January 2024
    The issue is probably the #-character, which refer to the installation directory, you want the @ which refers to the data directory, like this:
    #27,@Bitmaps\Icons\CONS.bmp:[Construction sheet/layer]{}|MCONS;
    (@ was new with CC3+, which means older instructions use # because everything was in the install directory then)
    And yea, you also need those number suffix files, those are for different toolbar sizes.
    Cenere
    edited January 2024
    Hmmm... I'm not sure, but you might try typing
    ffix on the command line and pressing the enter key.
    If you get a list of path updates, it was needed. If you don't get such a list, the problem is something else.
    If you get the list, save the map,exit the program. Then load it again.
    Cenere
    Did I make a mistake ?
  • Hi, thanks for helping.
    Problem solved🙂
    After replacing "#" with "@" some of the buttons became visible, some did not.
    Then I investigated why: I noticed that the dimension of "not working" bmp was different and bigger than "working" bmp, so the issue was related to the online tool I used to rescale the custom 16x16px which was adding some "unrequested content" to the converted files.
    After few attempts I found a converter without this problem and everything worked out.
    Thank you for your time.
    JimPRalf
