BUG Cthulhu City Template Metrics
Hello guys i dont know if this the correct way to report but i was doing tests for other projects and i found that on Issue Cthulhu City template Metrics appears kind a bug with metrics unit; the problem is no matter wich template you use the distance units is on feet. Anyone knows how fix it ??
I also check the documentation and i think there is anoher problem cause the pdf says that the map Sarnath City should be at least 2000 ft but when you open is 1000 ft so maybe something is doing strange things. But is probably just me i missunderstanding something :D
Yeah, the metric version there is not correctly set up. You can use the attached version instead, just replace the template (FCT file) with this one.
As for the example map... it was created a bit small. If you measure one of the larger streets, it's only 10' across, clearly too narrow for a proper city street.
i dont understand what you refer with "attached" version. :S I will replace anyway. Thank You
Edit: Works perfect the only thing but i think is not important when i start new map dosnt start at 0,0 coordinates but i am ok with it.
The "attached version" Ralf mentions is the "Annual Cthulhu City (metric).FCT" file - which is attached to Ralf's comment.
to change the origin in a map, 0,0,
just type origin in the command line at the bottom of CC3+.
Then click at where you want 0,0 to be.
