Issue with Node Edit
Hi Folks,
Re my current commission, SS4 Dunegoens of Schley map, I'm getting the structure sorted for the last map and despite the Grid layer being frozen, when I use Node Edit to move wall nodes, the Grid is highlighted and I can't select any other nodes. Why? It's extremely frustrating having to go and hide the grid - each time I want to move a bit here and there...which happens a lot - the layout is complex and labrythine.
The only thing I've done different in this map is, after drawing the intial grid via the menu and selecting the defaults, I had to re-size the map and I re-drew the grid by selecting points. I wouldn't have thought this would casue an issue...
I'm not having that problem. Check that your grid is on the layer you have frozen.
Hi Sue,
Double checked that before posting. I just double checked the double check as I was going to upload the FCW but it appears to be working correctly now... weird with a capital W.
Well, I'm glad it's working now anyway :)
