Exporting Climate View
genesisweapon
Newcomer
In FT3+, I've got the view you get from Map->Show Climate.
It is pretty much exactly how I'd like my export to look. Is there a template that will output a virtually identical view into CC3?
Thanks for any help you can offer!
Best Answer
Monsen
Administrator 🖼️ 82 images Cartographer
Note that you can always export the climate view from FT3+ to CC3+ just by going to File -> Save Campaign Cartographer file. There is an export setting there, Legacy Climate Only that will export the climate view, or you can make your own.
But it won't look identical to what you see in FT3+. FT3+ and CC3+ are two different programs that have different ways of doing things, the idea with the export functions is to get the actual data across so you can customize it in CC3+, not the exact visual look.
Answers
Thank you!
Thanks!
