I exploded a continent in ft3+, but I've forgotten how to put it back to filled in contours
I did search the forums, but I don't get it today. My search fu is probably off to.
Here is the jpg of a fcw file.
and the fcw file.
Thanks !
and the fcw file.
Thanks !
You've exploded it one time too many, Jim. Each of those lines is shattered into thousands of individual straight lines.
I recommend re-exporting the map and checking if you have multipolies or ordinary polygons before you explode anything. Then only explode the multipolies and only once.
Thanks. I had been trying to change properties on them back to solid and it didn't work.
I was able to fix it up the second time. I started back with the original fcw file, to get the one continent I wanted.
The LTP command might have also been an option to reassemble those chains. It's the command for reassembling paths that have been exploded into individual lines.
