Adding dots at grid intersections
I'd like to make a "dot grid" map - basically a tactical battle map with dots at the grid intersections instead of lines. I'm looking to experiment with something that has good guides for movement and mini placement, but that isn't as busy as a map with full grid lines. Certainly not a "must have" more of a "is that something that is relatively easy to do?"
The Rectangular Array command (REPEAT from the command line) will copy entities multiple times to form a rectangular array. If you use this command on a symbol such as a dot, then you can have a grid of dots. You can use this command with other entities than symbols if desired. Draw two little lines on a grid intersection and then use REPEAT on those two lines and you'll get the corners of each grid cell instead of the full grid cell.
Thanks - I'll play around with that.
