Catalog Configs
My catalog of symbols show only squares with one or two letters, i want put the symbols back to normal, as it originally, can anyone help me?
I have a photo of the problem
Hit the Options button at the top of the panel and reduce the number of columns, then increase the size of the symbols.
This is what my setup looks like for a single column of symbols. Most people have 2 columns, which is the default setup.
Here, dont chance nothing, the columns return to 0 every time and the simbols dont return to normal
Changed***
The columns stay in 1 just if he height and width of the symbols are 20, but stay with the ugly symbols
I'm not sure why it isn't working. If you put the panel on the left side where it is by default does it work then? I've never tried it on the right hand side.
If you can't get it to work on the left side either, or even if it does work on the left side but you really want it on the right side, please contact Tech Support through your registraiton page. There's a tab called Support.
And how i put on left side?
Funny you should say that, since I can't work out how you ended up with it on the right side. This is where it normally appears on the left hand side of the screen.
Was it on the left when you first ever opened CC3?
To change position of (or add) toolbars, go to View>Toolbars
This is the symbol pane, and on my installation it can only appear on the left. I just have a checkbox - no arrows.
No, at the first time that i start, was in the right side
Do you know any way to reset the settings to default? Maybe a reset solve the problem
If this is as it appeared to start with a reset (or reinstall) isn't likely to sove the problem, though you can try redownloading the installer and reinstalling the app if you wish.
I recommend contacting Tech Support with this issue.
Just change the positions using View>Toolbars, as i suggested. Not sure why you haven't tried this first.
What version of CC3+ are you running? I haven't seen toolbar icons like those for a long time and older CC3 versions may not be fully compatible with current versions of Windows.
Like Sue, I recommend contacting tech support about this problem.
You can't change the position of the catalogue this way - at least you can't in the current version of CC3+.
As far as I am aware this is the current version, and can be viewed under 'Abount CC3...' in the Help menu.
That looks a bit like an installation with insufficient rights (non-admin). Are you running CC3+ on a Windows account with reduced rights?
As a first thing, I'd try to run the latest update for CC3+ (update 28) . Download it from your registration page, right-click the file and choose "Run as Administrator" to execute it. Does that help?
If not, I would recommend a reinstall, making sure you also run the setup for CC3+ by right-clicking the file and choosing "Run as administrator" to execute it.
