Hex grids
I am trying to set up 2 different hex grids on 2 different layers or sheets one large and one small, when I try to setup a new layer or sheet with the add command then select the grid button it defaults back to the default layer or sheet. how do I get the grids on different layers or sheets and which one should I use a layer or sheet. also when I put both grids on the same layer they don't line up the way I would like how do I move one or the other to get the alignment I want between the two grids
Thanks
Steve
    Create the first grid, then move it to the desired sheet (The "edit properties" command), then create the second one (and move it if desired).
    To line up the grids, you will have to use the move command. Lining up differently sized hex grids can be difficult. Make sure you use compatible grid sizes.
