Shrinking symbols
When I made the floor outside the houses walls, everytime I try to put the symbols in it, they disappear.
They seem to go to the bottom of the floor I made. How can I prevent my symbols from going under the floor, so that they are visible? I tried to place furnace to the stone wall.
    edited June 2023
    Check your sheet order. Your floor is most likely on a sheet that appears after the symbols in the list. Use the List command from the info menu to check which sheet your floor and the symbols you are trying to place are, and adjust the ordering accordingly. Remember that stuff on sheets at the end of the order appears on top of things from sheets higher up.
    It is also possible that the sheet order is wrong and your symbols go to the wrong sheet. But this will also be revealed with a use of the List command. If the symbols are on the wrong sheet, use Change Properties on them to move them to the right one.
    ScottAJimPLoopysue
