Print Issue
I created the floorplan for a 4-story tower, but find that one of the floors prints with a lavender hue. They all display the same on the screen. None of the other floors do this, and all four were created in the same process (selected multiple floors in one new map creation). Anyone know what might be tinting when it goes to print?
Best Answers
    Accepted Answer
    It's the Edge Fade on the Floor Inlay sheet. I don't know what it's doing, but its causing the problem.
    If you switch off the Edge Fade the problem is cured.
    Edge Fade is usually used for country borders and not much else. Maybe you wanted an Edge Fade, Inner?
    PNW Angler
  • Jeff BJeff B Betatester 🖼️ 39 images Surveyor
    edited April 2023 Accepted Answer
    Sue,
    The edge effect works fine if you change the setting to use map units instead of Percent of View width and move it below the glow effect. suspect the effect is grabbing the purple glow. As during some playing around I had the entire CC3+ display window purple with the effect on.
    PNW,
    You should be using the map units option for your effects it will give you less problems than Percent of view width.
    JimPPNW AnglerLoopysue
Answers
