SOLVED: Why are my Dungeons of Schley textures blank in DD3?
edited April 2023 in Product Questions
SOLVED:
When creating a new map, I need to select 'Dungeons of Schley' as the map style.
In DD3, when I select 'Dungeons of Schley' as a style, all of the textures are the same as the plain fill colour.
I think I might have changed the default install location for Symbol Set 4 (Dungeons of Schley)... But I don't know the original to reinstall it back to! (C:\ProgramData\Profantasy\CC3Plus\....?)
Can anybody help?
Thanks!
    edited April 2023
    By default, templates only contain references to the fills used for the style (You REALLY don't want to have them all listed, trust me :)), so that means that drawing tools not made for the current map style will show up using the currently selected fill (see your status bar), instead of the actual fill used by that tool in it's native environment. (Your current map seems to be the Ancient Tombs style)
    There's more information in this FAQ topic, including how to import the fills to the current template:
    LoopysueJimProflo1Kit FlemonsEdE
