How change hex grid color?
Is there a menu option for changing the line colors for my map's background hex grid? I must be missing it.
If you do a change properties and select the grid does that do it?
Use the change properties button on the left. Select the grid, and then change the color. If it does not change, check to see that the grid layer is not frozen.
That did it, thank you!
